If you are on a Mac it appears you can use Symbolic Links to accomplish this.   A Symbolic Link(SymLink) is like an alias on steroids and basically tells the operating system to treat a single file or directory as if it exists in multiple places.   During my test, I used a SymLink from the Settings:DWG_DXF folder in my Workgroup folder back to the Settings folder in my User folder. Then when I saved a DXF Export Setting file it showed up in my Workgroup folder.   Th
