mraiff
2020 User Libraries
I am having a hard time getting my User Libraries to show up in the Resource Manager in 2020 on my Mac.
I have put the folders I want in User>Library>Application Support>Vectorworks>2020>Libraries. (also shown as my User Folder)
I have also tried putting it in the Application Libraries Folder.
No matter what I do, they don't show up in the RM. It worked just fine in 2019, so I'm a little lost.
Thanks for any advice !
4 answers to this question
Have you tried refreshing your Libraries or restarting vectorworks?
I think there was a change in how VW reads the Path.
I think in previous VW versions you had to select the Libraries Folder,
while since VW 2020 you need to select only the parent 2020 Folder.
(Trailing "/" needed or not ?)
Or something like this.
Doesn't matter for me, as I forget the right Path writing every September !
Each year I need 3-5 trial attempts until the Path finally works.
EDIT :
Sorry,
I miss-read and thought it is about the Workgroup Folder.
User Folder should work out of the box.
The only thing I can imagine is that you directly copied your VW 2019 Files
over into VW 2020 User Folder and it will ignore the older File Format.
At least I did a Batch Conversion of my VW 2019 Workspace Folder to VW 2020,
and (after I finally found the correct Path writing) my migrated Workspace data
appeared pretty quickly, while the Ressource Refresh.
Edited by zoomer
