Spotlight numbering issues
nicolas06
Hello everyone,
I'm quite new with spotlight, and I'm struggling a little bit with the numbering tool. I manage to use it for giving Id (or channels ..depending) and Universe/adress in my project (pic 1) 1925301922_spotlightnumbering1.thumb.png.c3781ef0431d0cca66c7ce59c08b18ae.png
but for some reasons now the field choice has changed and reduced and I can't access to all of the fields (pic 2) which is quiet annoying as I have to patch a hundreds of light now. Is there any particular reasons,  am I missing something ?
Thanx
Hi,
I'm running 2019 SP5.2, and it's the same file but it happened to me earlier with an another files which was qiet ligher than this one. I modified some stuffs in the lighting device parameters, like the unit Id and fixture Id but tried to reset it to default after while without any chances.
I haven't seen this problem before.
It looks like you are using a partially localized French version?
The dialog is in English but the parameters are in French in the first dialog.
The second dialog everything shown is in English.
I would contact your local tech support and see if they have seen this issue before.
