Daniel B. Chapman Posted September 17, 2019 Share Posted September 17, 2019 I'm curious if it is possible to assign a Data Tag or a Visualization to display the name of the objects in the OIP->Name field. I'm trying to use the new MVR workflows for Vision and I'd like a way to easily see the name of each major object. Is this possible? The tags and visualizations appear to search by the Records, not the inherent object. Quote Link to comment
Vectorworks, Inc Employee Nikolay Zhelyazkov Posted September 18, 2019 Vectorworks, Inc Employee Share Posted September 18, 2019 Hello @Daniel B. Chapman, You could use the Data Tag to achieve this. Simply use Object Function for Data Source and Object Name for function. Best Regards, Nikolay Zhelyazkov Quote Link to comment
Daniel B. Chapman Posted September 23, 2019 Author Share Posted September 23, 2019 Nikolay, Thanks for the information. Is there some sort of API that shows all the names? I'm having a heck of a time querying for the information I need in a smart way. For lack of a better example I'm looking to do something like: { Object.name, LightInfoRecord.channel, MyRecord.notes, } You got me pointed in the right direction, but I'd love a reference so I can create the information I'm looking for. Quote Link to comment
Vectorworks, Inc Employee Nikolay Zhelyazkov Posted September 24, 2019 Vectorworks, Inc Employee Share Posted September 24, 2019 Hello @Daniel B. Chapman, If I understand you correctly you want to extract this information for all of the objects in the document? If so, you could use Create Report menu command, select All Objects for Criteria and then in the columns group select the desired records/functions. See the image below. This will create a worksheet that lists the names of all objects in the document and the Channels of all Lighting Devices. Best Regards, Nikolay Zhelyazkov Quote Link to comment
Anttti Posted March 27, 2021 Share Posted March 27, 2021 On 9/17/2019 at 9:33 PM, Daniel B. Chapman said: I'm curious if it is possible to assign a Data Tag or a Visualization to display the name of the objects in the OIP->Name field. I'm kind of confused that there isn't a Data Tag Style showing simply the object name in the basic Vectorworks Libraries. You really have to do it yourself? Like, isn't a tag with the name the first, most basic thing you'd want to have? If we think about Data Tags as sort of smart Callouts? Or am I missing something fundamental on the idea and use of Data Tags? (If I understood previous replies correctly, assigning a Data Tag with the object name was in fact not what the original problem in this thread was about eventually, but anyway I wonder) Quote Link to comment
Daniel B. Chapman Posted March 27, 2021 Author Share Posted March 27, 2021 @Antti, No the response from Nikolay was off topic (I didn't need a channel hookup) and, honestly, I had forgotten about this topic. I was able to solve this using the Object Function `[#N#]` (which means name). It wasn't intuitive at all, but you can link the text in the Tag to a dynamic text field. I then used that to tag all of these architectural LED instances. Your point about lacking a basic tag in the libraries is valid, this took me quite a while to figure out. I don't remember the full process, but it was worthwhile when I finally finished it. My real problem here was tagging this information to match an outside model for previz. -Daniel Quote Link to comment
Andy Broomell Posted March 27, 2021 Share Posted March 27, 2021 @Daniel B. Chapman off topic, but what font is your “tag text”? Quote Link to comment
Daniel B. Chapman Posted March 27, 2021 Author Share Posted March 27, 2021 @Andy I'm pretty sure that's "Architect's Daughter". It is a cheeky drafting font. Quote Link to comment
