class naming tool
bgf.s
Hello there!
I'm trying to generate a marionette script for automatically naming and generating classes.
What I want it to do is, that a class is generated, and the selected object is put into the class. The naming scheme is mostly the same, so I tried to generate a dropdown menu and based on your choice there should be another choice. At last you put a text label in the third part of the name.
So for example: part a, part aa, my text.
I tried to put a few nodes together, but I am new to marionette. So I have the problem that once I select the first choice, the second is not determined by that and it does not work as intended.
In general the way this marionette works is incredible! I really do enjoy playing around with scripts and nodes in the forum, but since I am not educated in this field (yet), maybe someone with more experience can look at the attached file (it is a student version .vwx) and help me out!
Thank you in advance!
Kind regards
Ben
Edited by bgfs
  • 2 weeks later...
