Josh S Posted September 17, 2019 Share Posted September 17, 2019 Hi, Anyone able to point me to a tutorial on creating a ceiling in an attic space? I can fudge it and get it sort of the right size but it's a b it of a faff. There must be an easier way! It's probably something simple I am over looking? The roof is made up of roof faces and the ceiling a slab. Ideally I would be able to get the slab to intersect with the soffit of the roof. TIA, Josh Quote Link to comment
Guest Wes Gardner Posted September 18, 2019 Share Posted September 18, 2019 @Josh-gsy...maybe use the Split tool in the second mode and use the underside of the roof face as your guide to split the "ceiling". In this case, the ceiling is a simple extrude Quote Link to comment
Josh S Posted September 24, 2019 Author Share Posted September 24, 2019 Hi @Wes Gardner, that works well when creating the ceiling from and extrusion. I could use the cut extrusion, to create a polygon the correct size. Create a slab from that, giving me a correct slab for the ceiling. But I suppose is there any benefit at that point to using the slab for a ceiling over a simple extrusion? thanks, Josh Quote Link to comment
Guest Wes Gardner Posted September 24, 2019 Share Posted September 24, 2019 @Josh-gsy...that could work...you may have some issues at the edges...try a couple of simple ones and see which results produce the best objects for your design. Quote Link to comment
