In Vectorworks 2020, when using the Framing Member Tool to insert a Framing Member, the Framing Member is assigned to the class of the last previously inserted Symbol.
Create a default Blank File.
Import and insert a symbol that is set to insert to a class other than the None class.
Use the Framing Member Tool to draw a default Framing Member.
The drawn Framing Member is not in the current None class as expected, but instead it's in the class of the symbol.
Repeat with a different symbol assigned to another class, and the next Framing Member will be in the class of the second symbol.
willofmaine
VWIS164
3 answers to this question
