I have a file where the publish or print command will create a PDF of the current visible screen plane instead of the sheet that is selected. Attached is a pdf and a screen capture. The PDF was created using the publish command and selecting that sheet.
This is the second time it has happened, I had it happen to a file a few months ago but it didn't really matter so I didn't investigate. Every other file (100's) functions just fine. Is this a weird setting I accidentally changed or is it just a messed up file?
mreadshaw
Thanks
Rezz_Saltair_V1.pdf
1 answer to this question
