nakedeye Posted September 15, 2019 Share Posted September 15, 2019 Hi. I'm trying to use the data visualisation command to set truss colour coding. It works for truss just fine but not truss that has been converted into a hanging position. `Is there a away of showing these as well? 1 Quote Link to comment
Guest Wes Gardner Posted September 16, 2019 Share Posted September 16, 2019 @nakedeye.....I'm not in entertainment but I know a bit about the Data Viz tool...maybe you need to set your criteria to "Hanging Position" so that the data viz set can "see" it??? Wes Quote Link to comment
nakedeye Posted September 16, 2019 Author Share Posted September 16, 2019 Afraid not. I can get truss to colour no problem but as for Hanging positions not at all. Quote Link to comment
Guest Wes Gardner Posted September 17, 2019 Share Posted September 17, 2019 @nakedeye...if you can, post a sample file so we can see what's up... Wes Quote Link to comment
nakedeye Posted September 17, 2019 Author Share Posted September 17, 2019 Hi Wes, here you go. I've tried lots of different permutations of the criteria but can't get the two trusses to take the colour coding. Max Truss Colours Data Viz.vwx Quote Link to comment
Menemeth Posted September 19, 2019 Share Posted September 19, 2019 when your creating a data visualization under display criteria the colors dropdown choose objects with parameter to the right of that select hanging position in the dropdown, and then under that choose position name Quote Link to comment
Guest Wes Gardner Posted September 19, 2019 Share Posted September 19, 2019 Hi All, At this point, Data Vis does not support INOBJECT which is what would be needed to look inside the hanging position for the truss object. Wes Quote Link to comment
