2020 Viewport Attribute Scaling Bug
Taproot
3 answers to this question
Curious.  I've found this behavior to be repeatable in multiple files.  Here's some screen shots to further illustrate the behavior.  Note - these settings worked fine in 2019.
First image:  Two viewports.  The one on the right is 50% the scale of the one on the left.
579668000_ScreenShot2019-09-13at9_29_16PM.thumb.png.7501a0fb51fbd53c98dbe2c4d73743cd.png
Second Image:  The test was to see if the "line type scale" could be reduced to 50%.  This screen shot is a "preview" of the setting.  Note the "X's" in the fence line.  They are shown at the same relative spacing as in the larger viewport - as intended.  However:
260785353_ScreenShot2019-09-13at9_28_58PM.thumb.png.c1d20d10769ec630766729a1c18a7f61.png
Third Image: Once the user clicks OK, the line type display reverts to its default size.  Note, the X's now appear at the same spacing in both viewports.
Hatches don't change in either preview or after exiting the Advanced Viewport Properties dialog.
1854489546_ScreenShot2019-09-13at9_27_50PM.thumb.png.538a5f82a22bb0258f32e4919d88c99b.png
Edited by Taproot
Okay, I can replicate your problem when I use a Page Scale Complex Line Type: it goes to 50% as expected with "Preview," but not in the viewport itself.
However, the hatch, as long as it's Page Scale, does go to 50% of its original size, as expected.  Oh, wait, hold the phone.  Evidently that's only upon the first attempt.  After that, it appears to be as you say...
If I create a new viewport, and skip the "Preview," the hatch seems to respond to the Advanced Properties, but the line type scale does not.
Seems you've maybe stumbled on a bug.  But at least it's a sporadic bug... the best kind...
