Rob P 0 Posted September 13, 2019 This is probably something obvious, but I've searched for and can't find the answer... I've set up a text style for callouts which includes a white background so that the label is easy to read when overlapping a base plan - see image below: However, as you can see the background isn't showing... Settings for the text style are below: Any ideas anyone? [I'm running Landmark 2019 - not yet brave to install 2020] Thanks, Rob Quote Share this post Link to post
michaelk 537 Posted September 13, 2019 Does the callout object have a fill or is it set to none? Quote Share this post Link to post
Rob P 0 Posted September 13, 2019 Now I'm feeling stupid! I was expecting that by applying a background that would auto-generate a fill... Thanks for your help - my excuse is that I have to jump between AutoCAD/Keyscape, VW, SketchUp and Adobe as all my clients have their own styles and approaches... Cheers, Rob Quote Share this post Link to post
Itchy 39 Posted September 28, 2020 Having this problem now, even if you set the class object to have a fill, it doesn't take the style color at all? I would have thought that the text styling should override object settings. Otherwise it makes the background color selection in text styling useless with call outs? It works with standard text (by automatically changing the object fill settings) but not with call outs, so either a bug or an oversight? Might be fixed in 2021, waiting for the localized version so I haven't been able to test. Quote Share this post Link to post
Itchy 39 Posted October 13, 2020 On 9/29/2020 at 12:53 PM, Itchy said: Might be fixed in 2021, waiting for the localized version so I haven't been able to test. Same issue persistent in 2021. Text style fill & text color won't override class settings. Quote Share this post Link to post
