Gaspar Potocnik Posted September 12, 2019 Share Posted September 12, 2019 Beforehand I think this is great and something we've asked for some time, so Thanks! On the other hand, I haven't found any information that specially shows how it works so here are some questions: - I am guessing that the "Channel" field has to be the Unit number, can this be changed? - I've tried to use the numbering tool to get the DMX address populated but haven't found it, is the patch window the only way to get it done? If so, this is something to reconsider... - I've seen the Vision data mapping has vanished and for what I've tried it uses the same fields as the patch window, is this correct? Is this editable? Quote Link to comment
Guest Beckstorm Posted September 12, 2019 Share Posted September 12, 2019 @Gaspar Potocnik I hope below will get you up and running. 48 minutes ago, Gaspar Potocnik said: - I am guessing that the "Channel" field has to be the Unit number, can this be changed? Vectorworks is using the MVR data format and this can not be changed. You will need to have the following a Channel number (the number you use to select the device in the console), a Universe, and a DMX Address. there are new fields in the Lighting Device for 2020 that will give you some display options you can find more in the Vectorworks help http://app-help.vectorworks.net/2020/eng/VW2020_Guide/LightingDesign1/Lighting_device_properties.htm?rhhlterm=Lighting Device&rhsyns= 53 minutes ago, Gaspar Potocnik said: I've tried to use the numbering tool to get the DMX address populated but haven't found it, is the patch window the only way to get it done? If so, this is something to reconsider.. You can address fixture in 3 way with the Lighting Instrument tool using Auto numbering http://app-help.vectorworks.net/2020/eng/VW2020_Guide/LightingDesign1/Inserting_instruments.htm?rhhlterm=Lighting Instrument Tool&rhsyns= Spotlight numbering http://app-help.vectorworks.net/2020/eng/VW2020_Guide/LightingDesign2/Numbering_light_plot_objects.htm?rhhlterm=Spotlight Numbering command&rhsyns= Or the DMX Patch Window http://app-help.vectorworks.net/2020/eng/VW2020_Guide/LightingDesign2/DMX_patching.htm?rhhlterm=DMX Patch dialog box&rhsyns= 57 minutes ago, Gaspar Potocnik said: I've seen the Vision data mapping has vanished and for what I've tried it uses the same fields as the patch window, is this correct? Is this editable? Vision is now using the MVR standard and can not be changed at this time. Quote Link to comment
Gaspar Potocnik Posted September 12, 2019 Author Share Posted September 12, 2019 1 hour ago, BrandonSPP said: Vectorworks is using the MVR data format and this can not be changed. You will need to have the following a Channel number (the number you use to select the device in the console), a Universe, and a DMX Address. there are new fields in the Lighting Device for 2020 that will give you some display options you can find more in the Vectorworks help I can see the DMX address field in the OIP but not in the spotlight numbering ergo I cannot patch with that tool. It's good both apps are following a standard, it would just be nice to have this stated somewhere in the manual (at least I did not see it) since it will change workflows for people. Quote Link to comment
Guest Beckstorm Posted September 12, 2019 Share Posted September 12, 2019 3 minutes ago, Gaspar Potocnik said: I can see the DMX address field in the OIP but not in the spotlight numbering ergo I cannot patch with that tool. It's good both apps are following a standard, it would just be nice to have this stated somewhere in the manual (at least I did not see it) since it will change workflows for people. Take a look again as I defiantly see it. If you don't I would reach out to tech support Quote Link to comment
Vectorworks, Inc Employee klinzey Posted September 12, 2019 Vectorworks, Inc Employee Share Posted September 12, 2019 @Gaspar Potocnik 1 hour ago, Gaspar Potocnik said: It's good both apps are following a standard, it would just be nice to have this stated somewhere in the manual (at least I did not see it) since it will change workflows for people. A chart with how the fields are mapped is available in the help: http://app-help.vectorworks.net/2020/eng/index.htm#rhsyns= &t=VW2020_Guide%2FLightingDesign1%2FVisualizer_data_mapping.htm Quote Link to comment
