Alex.loo
VW2019 SP5.2 Bug - Organization
Hi,
since I've updated to SP5.2 i can't reorder the Design Layers or Sheet Layers via the Organization window. in SP5.1 it works.
Within the Navigation palletes I can reorder them as usual.
Is this a bug or a new "feature" ?
Best Regards
Alex
Using VW2019 SP5.2 on MacOS Mojave Version 10.14
2 answers to this question
Hi Alex,
When in the Organization dialog box click on the 'Stacking Order' column header and then you should be able to drag and drop layer stacking order. If a different column header is selected it will prevent you from using the drag and drop function. I hope this helps.
