Hi everyone,
I have notice that there is problem which I am constantly coming across with. Quite often, the renders I do result being different once I render them in a viewport window. For example:
This is a render I did on a design layer and both shape and texture look fine.
1649463752_Screenshot2019-09-12at11_26_59.thumb.png.0840225f0953bd1fa9f820fbc6c45d6d.png
But then, when I render through viewport on to a sheet layer, I end up having a different image:
2146292292_Screenshot2019-09-12at11_27_19.thumb.png.4dd428a57af67d0738ead2ec2fb876a8.png
The image looks blurred and the texture lose its original color. I  tried to scale up the viewport scale to see if at a bigger scale the resolution would change:
545968056_Screenshot2019-09-12at12_07_41.thumb.png.5aba305a79f068fac0361ca93ea0c604.png
and the image did improve in terms of sharpness but still the texture's color would not match the one I have in the design layer.
Another odd mistake I've bumped in to, is this:
1465180218_Screenshot2019-09-12at11_24_43.thumb.png.267d1dd7effc344345833b347b42bdfc.png
It did happens a few time now, that when I render a solid, on the final render image comes up a shape that is not supposed to be there.
In the green circle there's this black form that does not appear in the design layer as solid.
In this case the green circle should result just the same as the blue one.
All these little inconsistencies, often showed up in the final renders and even If I go back to try to sort them out I will not find the solution.
I am wondering if this could be due to hardware performance that are not matching the software requirements or maybe some render settings that need to be edited?
Once again, thanks for your help.
F.
In fact, we recommend doing your rendering in viewports...and as fabrica points out, you can change the DPI of the sheet layer...I usually go to 300 for anything rendered.  Yes, it takes a little longer for the rendering...
Thank you both.
Yes I did see that there is actually a difference in a better resolution. At the moment I am using only 100 dpi as it would really take time with more than that. But it is definitely something that I will bear in mind.
Anyhow, I still have to check the mistake with the black form, as that was one of the kind.
@Flavio did you solve the lack object issue?
Ideas:
That black object looks like it might be an object with no fill. Try to select and add fill, or assign to a class with fill and activate “by class” option for the fill attribute. Or make all attributes “by class” for that class
It could also be a duplicate with no fill, coincident/stacked on the filled version of the same object. It could also be a duplicate located at same position on another visible layer . Navigate to the black object on the design layer, set
Ayer visibility to Show Snap All, and marquee select the object. OIP should indicate whether duplicates are present.
Object in green circle might not be same class as blue circle object, and therefore might render differently.  Assign to same class as blue circle object, or adjust class attributes to match.
If destructive testing is required, duplicate your file, name it TEST or something logical.  Troubleshoot in the test file. Try delete or move the black object and render again. Look for duplicates on other layers by making such layers invisible, or delete (then undo if nec).
Post back if none of this helps
-B
Another idea for rendering in viewports is to set the sheet layer resolution really LOW so you get a quick initial rendering making sure all objects, the view, etc. etc. are set up correctly then jack up the DPI of the sheet to get final good-looking renderings.
So I figured out the black object problem. It was, in fact, as you guys pointed out a ghost object hidden underneath. I do not know how I managed to create it without attributes.
Odd.
