jonp0001 Posted September 10, 2019 Share Posted September 10, 2019 Hello I've just started using BIM tools for a working drawing and am struggling with some of the dimension controls. The attached is a screen shot showing a door insertion, the width in properties is 1023mm (which is correct for the structural opening for this door) red highlight, but when the door is inserted in the drawing the opening is cut to 1009mm blue highlight. I assume this is a finished dimension, but I need the opening to be structural for a construction drawing. It looks like it may have something to do with the extension lines highlighted green, but I can't figure out which property to amend. Help, as always, appreciated. Jon Quote Link to comment
fabrica Posted September 10, 2019 Share Posted September 10, 2019 might be shim gap? (set to 0 if not) 1 Quote Link to comment
jonp0001 Posted September 16, 2019 Author Share Posted September 16, 2019 fabrica - perfect, yes, thats solved the issue, thank you. Quote Link to comment
