Chris_W
Ultra Short Throw Projection
Hey guys --
Anyone have any tips on ultra short throw projection? I'm working on a drawing and need to draw an ultra short throw with a mirror'ed lens. Any way the screen tool can do it?
Broh. This is amazing!
Are you able to put them in the screen tool or do you just drop them in as objects? What about adjusting for different screen sizes?
If you're running Spotlight or are using the Landru Design version of the video tools, all you have to do is to add that file to the "...Libraries\Defaults\Video Screen\Projector Models" folder.  Then, when you use one of the projection tools, those projector models will be available to you.  The tools will handle screen sizing and projector placement for you.
Theres a fault with my projector data. You need to add "mm" to the measurements in the data records for these to work in imperial files.
Also, I think Vectorworks have changed the necessity to look in library files for the symbols. As far as I can see, the tool now looks for any symbol in the file or library files with the correct record attached (__VS-ModData)
3 hours ago, markdd said:
There's a fault with my projector data. You need to add "mm" to the measurements in the data records for these to work in imperial files.
The same thing is true if your units are in Imperial and you want your projector(s) to work in Metric files.  Units markers need to be included.
1 note:  Don't change the field formats in the Record from Text to Dimension.  They need to remain Text fields with units markers manually added.
The tools look in both places.  I simply suggested the external folder assuming the Symbols would be needed in files beyond the current model.
You guys rock! Thanks for the guidance.
A couple of questions... mind you this is coming from someone who isn't super familiar with this type of projection... (I'm an audio guy...don't tell anyone...)
While using this file with the screen tool, it seems the widest lens option available is .64, don't these lens' go down to .3? Do I need to just put it in as a custom value?
Also - It looks like the projector is placed below the floor. The only way to fix it is by putting the screen up high (Z=6'), which isn't physically possible in this room. Typically when I see these set up, they are close to inline with the bottom the screen... am I missing something? Changing alignment to bottom of screen doesn't really seem to do anything but change where the cone is.
At the end of the day, I just need to know how much room to leave behind it. The 3D render isn't terribly important.
image.thumb.png.64986d0a5f0929650c5098f05552002d.pngimage.thumb.png.da87f8f4c0e687290818e7066ac6e9f9.png
that should be corrected when you change the data to mm.
You will need to reload the projector for the change to take effect.
I'm not real familiar with Data Records... You mean in the Object Info pallet? I don't see a measurement field in any of the different formats?
Edited by Chris_W
edit the symbol, either 2D or 3D, go to the data tab with nothing selected and then add in the mm on the appropriate places.
For the current build of the Spotlight tools, yes, this is your best option.
