Chris_W Posted September 9, 2019 Share Posted September 9, 2019 Hey guys -- Anyone have any tips on ultra short throw projection? I'm working on a drawing and need to draw an ultra short throw with a mirror'ed lens. Any way the screen tool can do it? Quote Link to comment
markdd Posted September 9, 2019 Share Posted September 9, 2019 Take a look at this. Is this what you’re after? https://www.dropbox.com/s/nnxmxv3rrd9ykpl/Panasonic Projectors.vwx?dl=0 1 Quote Link to comment
Chris_W Posted September 9, 2019 Author Share Posted September 9, 2019 Broh. This is amazing! Are you able to put them in the screen tool or do you just drop them in as objects? What about adjusting for different screen sizes? Quote Link to comment
markdd Posted September 9, 2019 Share Posted September 9, 2019 Absolutely. Should be screen tool ready! 1 Quote Link to comment
C. Andrew Dunning Posted September 9, 2019 Share Posted September 9, 2019 24 minutes ago, Chris_W said: Are you able to put them in the screen tool or do you just drop them in as objects? What about adjusting for different screen sizes? If you're running Spotlight or are using the Landru Design version of the video tools, all you have to do is to add that file to the "...Libraries\Defaults\Video Screen\Projector Models" folder. Then, when you use one of the projection tools, those projector models will be available to you. The tools will handle screen sizing and projector placement for you. 1 Quote Link to comment
markdd Posted September 9, 2019 Share Posted September 9, 2019 Theres a fault with my projector data. You need to add "mm" to the measurements in the data records for these to work in imperial files. Also, I think Vectorworks have changed the necessity to look in library files for the symbols. As far as I can see, the tool now looks for any symbol in the file or library files with the correct record attached (__VS-ModData) 1 Quote Link to comment
C. Andrew Dunning Posted September 10, 2019 Share Posted September 10, 2019 3 hours ago, markdd said: There's a fault with my projector data. You need to add "mm" to the measurements in the data records for these to work in imperial files. The same thing is true if your units are in Imperial and you want your projector(s) to work in Metric files. Units markers need to be included. 1 note: Don't change the field formats in the Record from Text to Dimension. They need to remain Text fields with units markers manually added. 3 hours ago, markdd said: Also, I think Vectorworks have changed the necessity to look in library files for the symbols. As far as I can see, the tool now looks for any symbol in the file or library files with the correct record attached (__VS-ModData) The tools look in both places. I simply suggested the external folder assuming the Symbols would be needed in files beyond the current model. 1 Quote Link to comment
Chris_W Posted September 10, 2019 Author Share Posted September 10, 2019 You guys rock! Thanks for the guidance. A couple of questions... mind you this is coming from someone who isn't super familiar with this type of projection... (I'm an audio guy...don't tell anyone...) While using this file with the screen tool, it seems the widest lens option available is .64, don't these lens' go down to .3? Do I need to just put it in as a custom value? Also - It looks like the projector is placed below the floor. The only way to fix it is by putting the screen up high (Z=6'), which isn't physically possible in this room. Typically when I see these set up, they are close to inline with the bottom the screen... am I missing something? Changing alignment to bottom of screen doesn't really seem to do anything but change where the cone is. At the end of the day, I just need to know how much room to leave behind it. The 3D render isn't terribly important. Quote Link to comment
markdd Posted September 10, 2019 Share Posted September 10, 2019 that should be corrected when you change the data to mm. You will need to reload the projector for the change to take effect. Quote Link to comment
Chris_W Posted September 10, 2019 Author Share Posted September 10, 2019 (edited) I'm not real familiar with Data Records... You mean in the Object Info pallet? I don't see a measurement field in any of the different formats? Edited September 10, 2019 by Chris_W Quote Link to comment
Chris_W Posted September 10, 2019 Author Share Posted September 10, 2019 Bingo. Thanks, Rob. Quote Link to comment
C. Andrew Dunning Posted September 10, 2019 Share Posted September 10, 2019 3 hours ago, Chris_W said: While using this file with the screen tool, it seems the widest lens option available is .64, don't these lens' go down to .3? Do I need to just put it in as a custom value? For the current build of the Spotlight tools, yes, this is your best option. 1 Quote Link to comment
