acdeslx Posted September 9, 2019 Share Posted September 9, 2019 I'm trying to find a way to keep the instrument label consistent independent of how the light is rotated. However, as you can see in the example below, some numbers rotate and the "e2" -- which is made up of two fields --at the bottom of the fixture changes place depending on the rotation of the fixture. Ideally I want it to look the same -- basically the whole fixture including the labels should rotate the same -- for the fixture in any direction but neither right-reading or any other option seems to solve it. Do I need to make a separate label for when the fixture is rotated in different angles? Quote Link to comment
JBenghiat Posted September 9, 2019 Share Posted September 9, 2019 You can control how flipped text adjusts by adding or subtracting 0.02° to the text rotation to the legend. The text rotation is imperceptible. Your 2 and e fields swapping makes sense, as they maintain their relative relationship as the rotation changes. Choosing the Flip L/R option in the OIP should swap them on a per-unit basis. Quote Link to comment
