Hello Community!
This Saturday, May 30, from 9am – 12pm EDT we will be performing maintenance on the Vectorworks Community Board. During this time, the site will be unavailable.
Paolo
Symbol display control in Modern Dialogs
Hello,
I am using the symbol display control in a dialog to show various symbols to choose from.
I did not find a way to get user clicks on these controls, in the dialog handler.
Is there a way or should I couple each symbol with a clickable control?
Thank you for any advice,
Paolo
I have tried also with the Image Control that responds to clicks but I did not get it to display the symbol image!
I am doing this way:
hImg := CreateImgFromSymbol('AM-530', 128,128, 0, 11, 9);
if hImg <> nil then CreateImageControl(dialog1, 4, 200, 200, hImg);
but, though the hImg is not nil, the symbol is not displayed. It is replaced by the Vectorworks icon.
Below the code I am using to test.
Of course, replace ''AM-530" with a symbol in your document.
PROCEDURE Example;
VAR
dialog1 :INTEGER;
int     :INTEGER;
hImg : handle;
PROCEDURE dialog1_Handler(VAR item :LONGINT; data :LONGINT);
BEGIN
CASE item OF
	SetupDialogC:
	BEGIN
		SetItemClickable(dialog1, 4, TRUE);
		EnableItem(dialog1, 4, TRUE);
	END;
	4 : BEGIN
			writeln('Strike!');
		END;
END;
END;
BEGIN
writeln('Inizio');
dialog1 := CreateLayout('Example', TRUE, 'OK', 'Cancel');
{CreateSymbolDisplayControl(dialog1,  4,  'AM-530', 128, 128, 5, 0, 2);}
hImg := CreateImgFromSymbol('AM-530', 128,128, 5, 0, 2);
SetFirstLayoutItem(dialog1,  4);
int := RunLayoutDialog(dialog1, dialog1_Handler);
END;
RUN(Example);
Here's the results:
838738230_Schermata2019-09-07alle16_10_53.thumb.png.7ca99592f4e4ea5055c6b2f3a5d2eeb7.png
With the symbol control, the dialog is ok, but I cannot get clicks on the symbol…
802949179_Schermata2019-09-07alle16_11_37.thumb.png.867fca6e3647aff2be48faafbcf16f5a.png
With the image control, I get clicks fired, but not the correct image 🤔
Edited by Paolo
Thank you for your reply.
I have seen the attached example, but I need something different.
After various tries, I have opted for the image control, though I am not 100% happy because symbols converted in images shows a "2" in the lower right side of the icon (to show that are 2D symbols).
You can see (in the attached image) the difference between the big tile (obtained with CreateImgFromSymbol) and the smaller tiles (obtained with CreateImageControl).
It is not what I wish to get from a "Modern Dialog", but I can live with it...
307960845_Schermata2019-09-10alle20_51_23.thumb.png.c8369ed9cd4278f2732fd68f50f10cf1.png
For those that may be interested, since there are not plenty of examples around, here's the code to get the dialog above (kLib is the path to single files and folders whose name is, as symbols, in the vectorworks file at path symLib.
PROCEDURE Example;
const
kLib = '/Applications/Vectorworks 2019 IT/Risorse/Elementi base/Mouldings - Models/Cornices';
symLib = '/Applications/Vectorworks 2019 IT/Risorse/Elementi base/Mouldings - Models/Cornices/MouldingsLib.vwx';
maxFolders = 1000;
kTreeControlID = 4;
kChosenSymbol = 5;
kChosenText = 6;
kBackwardBtn = 7;
kForwardBtn = 8;
kPages = 9;
kFirstSymbol = 101;
kSymbolWidth = 50;
kRows 			= 6;
kColumns 		= 7;
TYPE
menuItem = STRUCTURE
	voce: string;
	idx : integer;
END;
VAR
dialog1 :INTEGER;
result  :INTEGER;
widthInChars, heightInChars :INTEGER;
root1, root2, child1, child2 :INTEGER;
folders : array[0..maxFolders] of menuItem;
buttons : array[0..maxFolders] of menuItem;
c, r : integer;
pagina, numeroPagine, numeroFiles: integer;
function validProfileFile(name: string): boolean;
begin
	validProfileFile := Pos('.cpf', name) > 0;
end;
procedure ricorsione(node: string; livello: integer; previous: integer);
var
i: integer;
foldername: string;
root: integer;
begin
i := 1;
folderName := GetFilesInFolder(node, 1);
WHILE (folderName <> '') DO BEGIN
	{writeln(livello, '. ', i, ' -> ', foldername);}
	{se è una folder, faccio un altro giro}
	if Pos('.', folderName) = 0 then
	begin {è una cartella}
		root := InsertTreeControlItem(dialog1, kTreeControlID, folderName, previous, livello);
		folders[root].voce := concat(node, '/', foldername);
		folders[root].idx := root;
		ricorsione(concat(node,'/', folderName), livello+1, root);
	end;
	i := i+1;
	folderName := GetFilesInFolder(node, i);
END;
end;
procedure updateDialog;
var
j : integer;
idx : integer;
begin
			for j := kFirstSymbol+(pagina-1)*kColumns*kRows to kFirstSymbol+(pagina)*kColumns*kRows-1 do
			begin
            idx := j-(pagina-1)*kColumns*kRows;
			beginContext;
			IF CopySymbol(symLib, buttons[j].voce) then
				begin
					Symbol(buttons[j].voce, 0, 0, 0);
					SetImageControlHandle(dialog1, idx,getObject(buttons[j].voce));
					SetItemClickable(dialog1, idx, TRUE);
					EnableItem(dialog1, idx, true);
					SetHelpText(dialog1, idx,buttons[j].voce);
					ShowItem(dialog1, idx, true);
				end else begin
					SetImageControlHandle(dialog1, idx,nil);
					SetHelpText(dialog1, idx,'');
					ShowItem(dialog1, idx, false);
				end;
			endContext(0);
			end;
end;
PROCEDURE Dialog_Handler(VAR item :LONGINT; data :LONGINT);
var
result: boolean;
i,j : integer;
fileName : string;
idItem : integer;
x : integer;
deltaPagina : integer;
BEGIN
x := item-kFirstSymbol;
deltaPagina := (pagina-1)*kRows*kColumns;
CASE item OF
	SetupDialogC:
		BEGIN
			ricorsione(klib, 1, -1);
			updateDialog;
		END;
	kTreeControlID : BEGIN
			{reinizializzo array}
			for i := 0 to maxFolders do
			begin
				buttons[i].voce := '';
			end;
			result := GetTreeControlSelectedItem(dialog1, kTreeControlID, idItem);
			i := 1;
			j := 0;
			fileName := GetFilesInFolder(folders[idItem].voce, i);
			WHILE (fileName <> '') DO BEGIN
				{se è un file…}
				if validProfileFile(fileName) then
				begin
					buttons[kFirstSymbol+j].voce := fileName;
				end else
				begin
					j := j-1;
				end;
				j := j+1;
				i := i+1;
			END;
			numeroFiles := j;
			pagina := 1;
			numeroPagine := trunc(j / (kColumns*kRows))+1;
			{completo con quelli vuoti}
			for j := j to kRows*kColumns do
				begin
					buttons[kFirstSymbol+j].voce := '';
				end;
			SetItemText(dialog1, kchosenText, 'choose a symbol');
			SetItemText(dialog1, kPages, concat(num2str(0, pagina), '/', num2Str(0, numeroPagine)));
			updateDialog;
		END;
	kBackwardBtn : BEGIN
			pagina := pagina - 1;
			if pagina < 1 then pagina := numeroPagine;
			updateDialog;
		END;
	kForwardBtn :BEGIN
			pagina := pagina + 1;
			if pagina > numeroPagine then pagina := 1;
			updateDialog;
		END;
	kFirstSymbol..kFirstSymbol+kRows*kColumns:
		BEGIN
			beginContext;
			IF CopySymbol(symLib, buttons[kFirstSymbol+x+deltaPagina].voce) then Symbol(buttons[kFirstSymbol+x+deltaPagina].voce, 0, 0, 0);
			updateSymbolDisplayControl(dialog1, kChosenSymbol, buttons[kFirstSymbol+x+deltaPagina].voce, 0, 2);
			SetHelpText(dialog1, kChosenSymbol,buttons[kFirstSymbol+x+deltaPagina].voce);
			endContext(0);
			SetItemText(dialog1, kchosenText, buttons[kFirstSymbol+x+deltaPagina].voce);
		END;
END;
END;
BEGIN
dialog1 := CreateLayout('Example Dialog', TRUE, 'OK', 'Cancel');
widthInChars := 28;
heightInChars := 28;
CreateTreeControl(dialog1, kTreeControlID, widthInChars, heightInChars);
SetFirstLayoutItem(dialog1, kTreeControlID);
CreateSymbolDisplayControl(dialog1,  kChosenSymbol, '', kSymbolWidth*3, kSymbolWidth*3, 5 , 0 , 2);
SetRightItem(dialog1, kTreeControlID, kChosenSymbol,0,0);
CreateStyledStatic(dialog1, kChosenText, 'Chosen symbol', 30,2);
SetStaticTextColor(dialog1, kchosenText, 256,0,0);
SetRightItem(dialog1, kChosenSymbol, kChosenText,0,0);
CreatePushButton(dialog1, kBackwardBtn, '<-️︎');
CreatePushButton(dialog1, kForwardBtn, '->️');
CreateCenteredStatic(dialog1, kPages, '1/1', 6);
SetBelowItem(dialog1, kTreeControlID,kBackwardBtn,0,0);
SetRightItem(dialog1, kBackwardBtn, kPages,0,0);
SetRightItem(dialog1, kPages, kForwardBtn,0,0);
	for c := 0 to kColumns-1 do
	for r := 0 to kRows-1 do
		begin
		{CreateSymbolDisplayControl(dialog1,  kFirstSymbol+c+kColumns*r, '', kSymbolWidth, kSymbolWidth, 5, 0, 2);}
		CreateImageControl(dialog1, kFirstSymbol+c+kColumns*r, kSymbolWidth, kSymbolWidth, nil);
		if (c=0) and (r = 0) then SetBelowItem(dialog1, kChosenSymbol, kFirstSymbol +c+kColumns*r,0,0);
		if (c=0) and (r > 0) then SetBelowItem(dialog1, kFirstSymbol +c+kColumns*(r-1), kFirstSymbol +c+kColumns*r,0,-1);
		if (c>0) then SetRightItem(dialog1, kFirstSymbol +c+kColumns*r-1, kFirstSymbol +c+kColumns*r,-1,0);
		end;
result := RunLayoutDialog(dialog1, Dialog_Handler);
END;
RUN(Example);
