See through visibility
Viewport renderings appear 'see through' , as the attached pdf.  This happens when exporting to pdf or publishing to pdf. Background renders are set to OpenGL  Renderworks. The walls are set to solid in the class settings. Foreground render is set to sketch. I thought it could be file size all be it the pdf file size is only 10MB, so I have tried to reduce the file size by reducing DPI of sheets to 72 or turning off 3 D people and trees and cars but this has not worked.
Any suggestions appreciated.
0458-WesthillPavillion-FeasibilityStudies-OPTION-7-test 2.pdf
