Pre-Select a choice in CreatePullDownMenu
WhoCanDo
Hi,
I have a CreatePullDownMenu in my Dialog Box and I have loaded it with AddChoice
How do I choose to select ItemIndex 10 on the PullDownMenu ?
I have been trying SelectChoice without luck.
SetFocusOnItem works to focus on the ComponentID but I also want to separately set ItemIndex 10 to be the focus.
Regards
Thanks Julian, I've tried SelectChoice among several others but it's still not working. Maybe I'm putting it in the wrong place, even though I've been moving it around during my attempts.
procedure test;
var StanDialog1 : longint; TF : boolean;
procedure CreatePopUpLayout;
  begin
  StanDialog1 := CreateLayout ('Component Data', False, 'OK', 'Cancel');
  CreateStaticText (StanDialog1, 4, 'Item:', 15);
  CreatePullDownMenu (StanDialog1, 5, 10);
  SetFirstLayoutItem (StanDialog1, 4); SetRightItem (StanDialog1, 4, 5, 0, 0);
  end;
procedure DialogHandler (var Item : longint; Data : longint);
    procedure InitiateDialog;
      begin
      AddChoice (StanDialog1, 5, ' ', 0);
      AddChoice (StanDialog1, 5, 'A', 1);
      AddChoice (StanDialog1, 5, 'B', 2);
      SelectChoice (StanDialog1, 5, 2, TF);
      end;
    procedure GetDialogEvents;
      begin
      end;
begin
Case Item of SetupDialogC: InitiateDialog;
  1 : GetDialogEvents;
  2 : ; { Cancel }
  end; { Case }
end;
begin
CreatePopUpLayout;
If (RunLayoutDialogN (StanDialog1, DialogHandler, True) = 1 { OK }) then begin end;
end;
run (test);
