Flavio Posted September 4, 2019 Share Posted September 4, 2019 Hi, While I was applying a texture to a solid I incurred in what I think is an error. So basically as you can see in the picture, the first solid on the left has the texture aligned in the right direction all along its lenght. In the second solid on the right instead the texture is divided in two and it follows different inclination. I did set the render settings in the same way. Anyone knows where the problem might be? Thanks Flavio Quote Link to comment
