VW11.5: Globally change Class Visibility in Saved Views
I have done a search and can find no info on this.
Is there a way to change a class's visibility in all saved views at once?
Example: I have 20 saved views, (sheets). For some reason the Nonplot Class is visible, (which of course means that it is no longer Non-plot).
Opening each of the 20 saved views to change that class to invisible is tedious. There has got to be a better way.
open up classes, highlight the class (nonplot in this case) and then click on the Saved Views button. You can then choose all the saved views by selecting the first, holding down shift and selecting the last (or holding down ctrl and individually picking them), then choose the visibility.
mdarch;
Thank you so much. How interesting that the answer has been right in front of my nose for so long. I looked at that class dialog box for hundreds of times and never noticed the saved views button.
Your instructions worked like a charm. This will save me many hours of tedium.
Glad that you have joined the discussion board.
