Paolo Posted August 29, 2019 Share Posted August 29, 2019 Hello, Is there a way to get a pulldown control in a VectorScript dialog that may have items with submenus, like the classes pulldown menu? I have explored functions the topic "Dialogs - Modern" of the VectorScript references, but did not find any clue. Yes, there is a tree control, but I have to remain in the size of a popup (more or less) for space needs. Any help? Thanks, Paolo Quote Link to comment
JBenghiat Posted August 30, 2019 Share Posted August 30, 2019 I don't think so. You can add a class pulldown menu. You can also create a list browser with hierarchical rows. Quote Link to comment
Paolo Posted August 31, 2019 Author Share Posted August 31, 2019 Thank you for the answer. Is the list browser you mention, the so called “tree control”? I need a pulldown menu that acts like the class pulldown menu, but I have to populate it with folder names contained in nested folders. Currently I have to keep all folders together to have “one level” only for these pulldown menu limitations, but I’d like to have subfolders (and submenus)... Quote Link to comment
Miguel Barrera Posted September 1, 2019 Share Posted September 1, 2019 As JBenghiat said, there is no way to create a pulldown with submenus out of the box but you can simulate something similar. Before the tree control, I had the same problem trying to show symbols located in subfolders. It has been a long time but I think what I did was to mark folders that had submenus. When the user click the marked folder, I would clear the menu and show the contents of the parent folder with the parent as the first item and then the contents offset by a couple of spaces. When the user clicked the parent header folder, I would show the higher level once again. Of course you need to keep track somehow the relationship between parent and nested items or folders. 1 Quote Link to comment
JBenghiat Posted September 2, 2019 Share Posted September 2, 2019 On 8/31/2019 at 1:50 PM, Paolo said: Is the list browser you mention, the so called “tree control”? The list browser is what's used in the Organization Dialog to show nested classes. On 8/31/2019 at 1:50 PM, Paolo said: I need a pulldown menu that acts like the class pulldown menu, but I have to populate it with folder names contained in nested folders. Currently I have to keep all folders together to have “one level” only for these pulldown menu limitations, but I’d like to have subfolders (and submenus)... The quick and dirty solution for this is not unlike @Miguel Barrera's solution: use a list box to display all folders, including a Top or Root option. Show all sub folders prepended with spaces. Use a second list box to the right with the contents of each older. Before resource manager pop-ups, this is how most of VW's symbol selection dialogs worked. 1 Quote Link to comment
