SimonRossiter Posted August 28, 2019 Share Posted August 28, 2019 Hi - Just adding Mac Encore Performances to Vision for the first time. It appears to me as though the Zoom range is inverted (min=wide and max=narrow) relative to the ETC Eos profile (with which I have had no problems in the past). Is this a known issue for others? Or is there a way for me to invert that part of the profile in Vision? Thanks Quote Link to comment
Vectorworks, Inc Employee bbudzon Posted August 28, 2019 Vectorworks, Inc Employee Share Posted August 28, 2019 Hmm, we have an option for inverting pan/tilt, but not zoom 😧 Perhaps, @Mark Eli or can chime in here? If the content just needs updated, it might be a quick fix. Quote Link to comment
Charlie Winter Posted August 28, 2019 Share Posted August 28, 2019 (edited) @SimonRossiter It sounds like the fixture is operating correctly according to its DMX chart. Always check the chart first, because fixture profiles vary across lighting consoles and programmers. Edited August 28, 2019 by Charlie Winter Quote Link to comment
Jesse Cogswell Posted August 31, 2019 Share Posted August 31, 2019 I just did a show last month with Encores and can confirm that the zoom is backward from both the ETC Eos profile as well as reality. For the previs, I built a custom profile for the fixture that inverted the zoom range, but had to correct it when I got in the space. Also, I don't think an option to invert zoom within Vision would be a great idea. Pan and tilt should be inverted because a fixture might change orientation from the plot to where it's hung based on cable runs, power, etc. Being able to change pan and tilt quickly to match reality without having to rotate or move the fixture within Vision is great. The only time you would need to invert the zoom is if the profile within either the console or Vision were wrong. 1 1 Quote Link to comment
SimonRossiter Posted September 1, 2019 Author Share Posted September 1, 2019 @Jesse Cogswell Glad to hear I'm not losing my mind! @Mark Eli Any word if this is a known discrepancy, and/or if there is an anticipated change to the profile? Quote Link to comment
Vectorworks, Inc Employee Mark Eli Posted October 30, 2019 Vectorworks, Inc Employee Share Posted October 30, 2019 Hi All, I've made some adjustments to the encore. You'll need to update your library in Vision and then restart the program to see the changes. Quote Link to comment
