2020 Teaser Tuesday - VGM Level of Detail - Vectorworks 2020
JuanP
@JuanP looks fantastic! Will this improve the Performance of 'Multiple Pane Views' as well?
I find that when I use 'Multiple Pane Views' with say one OpenGL perspective and one plan view window, the graphic performance of VW is drastically slower than just using one View Pane.
I currently use a RX580 (8GB) graphics card and thinking of upgrading to a Vega 56.
Questions:
(1) Would the above VGM improve the Multiple Pane View performance?
(2) Would the performance of Multiple Pane View improve with my said upgrade of GPU? Is Multiple Pane View performance GPU-bound?
I am also very interested to know how this will affect working with point cloud data. I have been working with Faro Scene, and it seems to handle very large (243 million) clouds without much trouble - very snappy. Taking for granted that VW handles pointclouds in a different way than Scene, it still seems crazy to me that after reducing the point cloud to 1/100th the number of points, it is still maxing out the ram on my machine and nearly crashing VW (and this with a fairly powerful gaming computer)
I recently switched over to VW in part because of the integrate point cloud capability, as Laser scanning is becoming a core part of my workflow, but without improvements to performance when handling point clouds, the feature will be severely lacking.
On a positive note, I discovered a great workaround, which is to use clipping cubes in Faro Scene to export smaller blocks of the full project point cloud, which break up at specific planes on the VW project - eg. "top of slab" levels. This way, the smaller sectioned point clouds can be associated with the story layers, and toggle on and off when needed. Saves a lot on performance, and makes them easier to visualize, as well.
Edited by mgebel
  • Like 3
Questions:
Yes, these VGM Improvements could help with Multiple View Panes. However, it is probably going to depend more on what type of geometry you have. A lot of the improvements that we have seen are with native VW objects, especially curved geometry like Truss and Lighting Devices. If you have a bunch of that type of stuff in your file, you will probably see a bigger improvement, even with Multiple View Panes.
Good point! I also like your workaround with the Clip Cube. However, I don't know how much improvement you will see with just Point Cloud data and the VGM imrpovements in 2020. I think you will see some benefit with less RAM usage, but for overall performance with point cloud data, I would expect it to be similar to 2019. This task was more focused on simplifying geometry.
On 8/28/2019 at 9:29 PM, line-weight said:
Bit odd the way this is explained in the video, as if it's resolving a fault in users rather than in the software.
If setting the quality to 'very high' means that VW draws stuff in the distance in more detail than is necessary then that doesn't mean that users are making a 'wrong' choice, it means that VW is doing it wrong.
(For context; I provide Tech Support for clients of the New Zealand distributor, Megabits).
As someone who frequently gets online with users and gets to see how people set up and use Vectorworks, I observe:
  • Most/Many users don't have an appreciation of how powerful their computer is or is not.
  • Whether or not users know how powerful their computer is or is not, they often don't know:
    • What Vectorworks or graphics card settings affect performance
    • What conditions in their file play a role in performance
So my take on what they said is this: This new capability means users can get better performance from Vectorworks regardless of how much they know. (Which is good design).
  • Like 3
Sure. But my point is that if setting to "high quality" results in VW drawing in more detail than necessary, then that is somewhat independent of how much users know. Even a user with a high awareness of their computer's power and the conditions in their file would reasonably expect that setting something to a "higher" quality would provide some kind of advantage in exchange for slower zooming, etc.
The way I see it, the way in which "how much users know" would affect things, is by users knowing "VW doesn't work properly therefore I have to change a setting to compensate" which indicates bad software design. But this new capability (hopefully) is an example of better design.
  • Administrator
On 8/29/2019 at 10:49 AM, Mark Aceto said:
  1. Making more of the code multi-threaded, which you just answered
  2. Lifting the 4-core limit (on modeling not rendering), which is still a mystery
Please let us know where we stand with #2, including a roadmap of the version/year ahead.
Sorry for the delay.
2. We have excessive thread blocking in a supporting library, causing us to set the three core limit. We are looking at possibly lift this limitation in the next version, but we can't promise anything yet. We will have more information Q2 next year. I will keep you all posted.
  • Sad 2
  • JuanP unpinned this topic
