ghunter
Reset Braceworks IDs not working in SP4?
I recently upgraded to SP4 and when I use the Reset Braceworks IDs command in any existing plans, VW crashes.  The progress dialog displays but about half way in there is a crash.  I created some simple new test plans, they seem to reset properly but then they don't contain anywhere near the number of hoists/truss etc as the existing plans.  Is anyone experiencing this issue?
Thanks
I have had the same when resetting the IDs with nothing selected, It seems to try to set an ID for every object in the drawing
I had the same in one drawing a while back. It turned out to be an issue with a lighting unit's Braceworks ID. When you reset, it resets everything. I sent the file to tech support and they are the ones who found the issue.
Thanks Scott.  OzCAD here in Australia confirms it crashes in SP4 and beta SP5 so a report has been raised.  I am going to revert to SP3.
