katebjohnson Posted May 27, 2005 Share Posted May 27, 2005 We are having trouble setting up perspectives in viewports. Occasionally they work, but more often than not we end up with a tiny portion of the image in the corner of the sheet. With the flyover tools and other 3D view tools disabled by viewports it is difficult to control the perspective. I generally set up my models in with a layer link and name the design layer "the Whole". Without using viewports I can have great control over the image. We recently got Renderworks and would like to do a multi-layer (multi-viewported) image. Is anyone else having trouble with perspectives in viewports?? It may be more of a problem in 11.5 than 11.0.1 Quote Link to comment
Delmer Posted May 28, 2005 Share Posted May 28, 2005 Edit viewport, go into Crop and use the view tools there. Should work. Quote Link to comment
katebjohnson Posted May 28, 2005 Author Share Posted May 28, 2005 Delmer, You are brilliant! Problem solved. I should have written sooner. Thanks! Kate Quote Link to comment
