Un-group or Explode Symbol Script
MTRobin
Hi Everyone,
I have a script that converts a symbol to a group and then ungroups it. This is assigned to a shortcut so I can quickly "explode" symbols. I would like to add an IF statement so if the selected objects are a symbol is will convert symbol to group and then ungroup it. If it is a group it will just ungroup it. It would be great if this worked with a multiple selection of a mixture of groups and symbols. Can anyone help me write the IF statement?
PROCEDURE ExplodeSymbol;
VAR
Selection : HANDLE;
BEGIN
    Selection:= FSActLayer;
    SymbolToGroup(Selection,0);
    Ungroup;
END;
Run(ExplodeSymbol);
Thank you,
Maxwell
Untested
VAR
	Selection : HANDLE;
	arrSelH   : dynarray[] OF handle;
	numObjects : integer;
	i			:INTEGER;
	hPrev		:HANDLE;
FUNCTION AddToArr( h :HANDLE) : boolean;
	BEGIN
		numObjects := numObjects + 1;
		arrSelH[numObjects] := h;
	END;
BEGIN
	ALLOCATE arrSelH[1..Count('sel=true')];
	numObjects := 0;
	ForEachObjectInList( AddToArr, 2, 0, FSActLayer );
	FOR i:=1 TO numObjects DO BEGIN
		if GetTypeN( arrSelH[i]) = 15 THEN BEGIN
			hPrev := PrevObj( arrSelH[i]);
			SymbolToGroup( arrSelH[i], 0);
			arrSelH[i] := NextObj(hPrev);
		END;
		if GetTypeN( arrSelH[i]) = 11 THEN begin
			HUngroup( arrSelH[i]);
		END;
	END;
END;
Run(ExplodeSymbol);
Try this.  It will only go on level deep.  If you want to explode symbols in symbols or you want to ungroup groups within groups more is needed.
PROCEDURE Explode( h :HANDLE);
    BEGIN
        IF Gettype(h) = 15 THEN
            BEGIN
                SymbolToGroup(h,0);
                HUngroup(h);
            END
        ELSE IF Gettype(h) = 11 THEN
            HUngroup(h);
    END; {PROCEDURE Explode}
BEGIN
    ForEachObject( Explode, ((SEL=TRUE)));
END;
Run(ExplodeSymbol);
On 8/20/2019 at 7:09 PM, MTRobin said:
Thank you!
I am getting an error message. Please see attached.
Best,
Maxwell
Looking at Sam’s code, Count('sel=true') should probably be Count((SEL=TRUE))
I might also start with setting numObjects := Count((SEL==TRUE)) and testing:
IF numObjects > 0 THEN BEGIN
Allocate....
