David Bracher Posted August 18, 2019 Share Posted August 18, 2019 Hi All, I try to create a view port - I do this , however the view port is very blurry in GL option mode , however very clear on the original design , why ?? Huge help please Thanks David Quote Link to comment
halfcoupler Posted August 18, 2019 Share Posted August 18, 2019 (edited) try these settings that influence the appearance of GL viewports: - in the object info pallette there is "Backgrund Render Settings". If it is set to "low", circles appear more as polygons, "very high" makes all curves smooth, but increases the size of the file when exporting - the sheet layer itself has a setting for resolution. ( Right click on the sheet layer in the Navigation palette, "Edit...") If it is set to 72 DPI it gets blurry, for a clear Open GL you should use min. 200 DPI, better 300 DPI, but this also increases the size of the file when exporting. Hope this helps .... Edited August 18, 2019 by halfcouple Quote Link to comment
David Bracher Posted August 18, 2019 Author Share Posted August 18, 2019 YES - thank you so much m it worked , I was going crazy - have a great Sunday 🙂 Quote Link to comment
