Objects by Criteria-Settings
MRoth
Hello everybody
I would like to create a menu command that works with selected objects. For this I use Objects by Criteria-Node. However, I'm not quite comfortable with the settings. What I want to do is always work with the currently active objects. One difficulty is that I only want to edit objects that I could edit with the computermouse at the moment. This means that when I am working in a group, selected objects outside of this group should not be listed, but those inside the group should be appear. The same goes for layers. Selected objects that are on another invisible layer should not be listed.
What are the settings for this?
  • 9 months later...
  • 2 years later...
