Fosterbryce8 Posted August 14, 2019 Share Posted August 14, 2019 Hi all, I've noticed with multiple file that in spotlight settings, "export on exit" never stays checked on. causing a lot on reconciling with Lightwright. Has anyone had this issue or know ways to fix it. Thanks for the help! Quote Link to comment
0 Vectorworks, Inc Employee klinzey Posted August 16, 2019 Vectorworks, Inc Employee Share Posted August 16, 2019 This is working as designed. "Exit" is on exit from the dialog, not exiting the application. The option will be always be unchecked when you launch the dialog. Checking this option forces a full export from Vectorworks and causes Lightwright to reconcile with Vectorworks. Vectorworks will cause Lightwright to automatically reconcile if the data exchange file is bad or has been deleted and needs to be recreated. Quote Link to comment
Fosterbryce8
Hi all,
1 answer to this question
