Problem to Import .OBJ File (Textures)
Guest Paulo Ferrari
Guest Paulo Ferrari
Hi my friends
I have some problems to import .OBJ files, follow  the link to download one of these files. When I tried to import this .OBJ, the textures doesn’t import (Appears this message in attach). Import only the 3D Object without textures.
http://vectorworks.com.br/temporario/Obj_File.zip
Anyone have a idea, what it's happen?
Regards
Paulo Renan Ferrari
Technical Manager
@Paulo Ferrari There are some textures you do not need. For example VW does not use normal maps (bump only) so it depends on which 2 textures you have missing. You may not need them. I guess you may only need diffuse. I say this because the extra textures will increase the file size which you try to avoid.
Edited by barkest
