REYES Posted August 13, 2019 Share Posted August 13, 2019 I realized I put this in the wrong tab so I move it here: For some reason it won't let me to add new Hardware to a door. After clicking manage hardware the Door Hardware library "Add" and "Remove" tabs apear as grays nd it won't let me to edit them either. It's probably related to my Door hardware library being Read Only mode. Which I don't know how to switch from. I'm the only one with this issue in the office and we can't figure out what I have different from other users. See screenshot attached. It happens both in project sharing files and in new files. It'd be great if anyone can help out. thanks Quote Link to comment
Vectorworks, Inc Employee Judah Warshaw Posted August 13, 2019 Vectorworks, Inc Employee Share Posted August 13, 2019 The door hardware definitions are found in the folder Libraries\Defaults\Door - Hardware in the file Door Hardware Library.txt If this file is set to read only then you will get the result you are seeing. Be sure the check the file in your user folder. This takes precedence over one in the application folder. Typically the files in the application folder are read only. You will have to check you file attributes to be sure. Quote Link to comment
REYES Posted August 13, 2019 Author Share Posted August 13, 2019 Thanks Judah, that worked! Quote Link to comment
