livespace josha
(humorous) Speaker array & data tag problem
Built a speaker array with the components I needed, and created a data tag to notate the array name and its weight. VW decided to be VERY accurate, but...
I adjusted the drawings units, re-entered each of the components weight, deleted and re-inserted the data tag...no luck.
Also, the units of measurement aren't transferring to the data tag.
Any ideas?
(btw...the array weight should have been 885lbs. The difference is 0.00000072 lbs, or about 14 grains of sand.)
1143141759_ScreenShot2019-08-12at4_13_22PM.thumb.png.ccc1bc0ffc41aaee5f7b41ab885f202d.png
3 answers to this question
Hello,
Could I ask you for a simple test file and I will analyze the problem.
Thanks,
Kostadin Ivanov
As I can see from your file, if you use the "Sub weight" data tag style, everything is working. Do I miss something?
