Spotlight - Draw Beam not executed
mkue
190813_DrawBeam.vwxHi All,
i try to write a script to toggle the "Draw Beam" option in the Lighting Instruments OIP. The goal is to switch quickly between beam visualization on/off  of the different lighting instruments.
I can see the checkmark appearing and disappearing after executing my script. However the function does not work, the beam is not shown/not disappears. If i check/uncheck the box it works as expected.
Apart of that, how can i implement a selection by popup for the different instrument types? the script only works with the "Object by criteria" node, even if i paste the full criteria (('Lighting Device'.'Inst Type'='Robe BMFL Washbeam')) to a string node it does not work.
Also i would like to have the draw beam on/off options as radiobuttons in a user popup but can´t find a node which does this.
Tia
Michael
190813_DrawBeam.vwx
Edited by mkue
Hi Pascal,
sorry for the late answer and thank you for your answer, this is a brilliant workaround and it works like charm!
Do you have any idea maybe why the dropdown list does not work?
For my understanding i would need to have a input port in the  "Objects by criteria" node where i can put in the criteria,
coming from my field names list. Or is there another option to do that which i dont see?
Also which node do i need to use to generate a user popup with radiobuttons for "true" and"false" ?
With the existing node i can only choose 3 options in the OIP.
Thank you in advance.
Regards,
Michael
Edited by mkue
  • 3 weeks later...
  • 1 month later...
