Julian Beckett Posted May 25, 2005 Share Posted May 25, 2005 Everything fine until a couple of days ago, then suddenly VW11.5 runs excruciatingly slowly. But only when logged into the network. When logged in locally the problem goes away! Is there a working folder path (scratch disk?) etc for V.Works? It might be trying to write temp files to a location stored within their profile ? hence over the network If so, can I change the path to a location on C: ? Quote Link to comment
Teun at KCAP Posted May 25, 2005 Share Posted May 25, 2005 Hi, Yes we have the same problem also described in this form see: http://techboard.nemetschek.net/ubb/ultimatebb.php?ubb=get_topic;f=12;t=004584 It looks like it only happens on a network with de network licence (serial numbers)i think vecorworks looks for free numbers and this slows down sometimes. I don't have a solution accept, pulling the network plug after opening the drawing from the network. I don't think it has to do with temp files, vectorwork doesn't use them, I thought Greetings Teun [ 05-25-2005, 10:43 AM: Message edited by: Teun at KCAP ] Quote Link to comment
Bruce Pittard Posted May 27, 2005 Share Posted May 27, 2005 I found turning off the new Accelerated navigation preference helps Quote Link to comment
