  • 2
KumaCAD
Custom Window & Door Trim Profiles
I do a lot of interior renderings & I was wondering if it is possible to add a custom trim profile feature to the door & window tools?
I currently work by having no interior & exterior trim selected in the tool parameters, I create an extrude along path with a 2d polygon as the trim profile, I place it on the jamb manually.  I then need to make this entire assembly a symbol to place it in a wall.
I apologize if this has been addressed elsewhere as I'm new to this forum. This seems like could be a common issue for those trying to create realistic renderings. I included a image of a door with custom trim on a work in progress.
Thanks933521679_ScreenShot2019-08-06at11_53_04AM.thumb.jpg.588ee80ae0abf6ac1d36665f01e2e85d.jpg
  • Like 3
4 answers to this question
This may be asking a lot, but it would also be nice if you could reference a 2d symbol for the profile on a path object(extrude along a path).
This would allow me to just switch out the 2d symbol's profile when a client would like to change the design of the crown or baseboard, for example, to a different shape, rather than having to edit each path object to trade out the profiles manually.  This is a very common work flow issue that I on run into...
  • Like 4
You might find a solution in this thread:
