Brandwein 6 Posted August 6, 2019 Is there a way to remove a crop from an image? That is, restore the entire image so the crop can be adjusted. I''ve tried edit crop, and I am told an image can't have more than one crop. Thanks! Quote Share this post Link to post
TKA 28 Posted August 6, 2019 if you erase old crop then it will let you do a new one the way you want Quote Share this post Link to post
Pat Stanford 1,627 Posted August 6, 2019 Or use the 2D tools (reshape, add surface, clip surface) to edit the existing object to what you need. Quote Share this post Link to post
O Design 9 Posted August 10, 2019 (edited) Crops do not work when you have more than one shape inside the crop. When you go into the image to edit the crop, delete the crop shape already there first or as Pat suggests simply edit the shape already there. Keep in mind that you can use polygons and circles as crops not just rectangles so can create complex shapes to suit what you need to hide and show of the image. Deleting the crop will restore the image to it's full extent. Edited August 10, 2019 by O Design Quote Share this post Link to post
