digitalcarbon
3d point clouds - need to rethink
i understand the value of a point cloud but when a 32gb file shows up at your door...you need to be prepared for it...and that was only 1/2 the bldg..
Edited by digitalcarbon
Also - Even though you may receive a tiny cloud point file (85 meg), if you aren't careful in the 'create site plan' dialog, you can balloon your Vectorworks file quickly. I managed to turn an 85 meg point cloud file into a 15 GB Vectorworks site model file at the push of a button. I feel like there should be a Vectorworks 'off-line process' system. Maybe on AWS or Azure. You drop your huge point file, move some sliders and come back a day later for the useable VW file. At least that way you don't turn your main workstation into a useless space heater for a days at a time.
Maybe a 'file size' slider and a 'Resolution' slider that are tied together. More resolution, higher file size. Do some background math to set up an approximate 'final outcome' of resolution (number of points) and file size (actual file size of the Vectorworks file).
I guess that is the point...just because you can read a point cloud file does not mean you know what you are doing...we need to be careful in what we say to clients....sure i figured it out in a few days but it took a few days...I had to chop the point cloud in to 20ft wide ribbons and then turn off every other one....something the clipped cube could not help with...
Hello,
I'm confused as there is the 'Import Point Cloud Options' dialogue that enables some control on the way in. Is this impractical?
Also the Model>Point Cloud>Extract 3D Loci from Point Cloud command is also user controllable. BTW the 3D conversion resolution makes no difference to the file size when importing Point Clouds. It is what it is in terms of the data and the filtering that Vectorworks allows. There's a good Donationware program for the macOS at least called Cloud Compare that you might find useful.
Cheers,
Peter
Edited by Peter Neufeld
Typo
@Peter Neufeld - Thanks so much for the info on 'Cloud Compare'. I downloaded it, and it gives me a very clear view into the source material. that is an incredibly powerful app.
The Vectorworks import point cloud options' tool set seems, well, totally useless. You can import (in my case) 20,000,000 points in a few seconds. It's not until you get into 'extract 3d Loci' that Vectorworks seems to do anything. Frankly, I can find zero things that the Import tool is good for. It should just be like a PDF. Drag it and drop it into the vectorworks document.
Ok...I'm slowing getting it...everything has a place and purpose...Sledge hammers and Tack hammers...it all depends on the task...
The 1st image (project 1) is a point cloud I got by making a video fly over of a 3d building on Google Earth then used the VW point cloud from images feature...very very useful for me...
The 2nd image (project 2) is me reaching in to find out how the framing is...3d scanner not going to get this...
@digitalcarbon I'd be interested to know how useful that point cloud in image 1 really turns out to be. I don't know exactly what data you need and for what, but looking at your survey notes it seems you want something reasonably accurate and detailed. My guess is there will be lots of visits back with a tape measure, that take up as much time as it would have taken just to do it the 'old skool' way from the start. Plus a bunch of fiddling around to convert everything into objects that are actually meaningful to VW.
@digitalcarboncan you give us a little more info on just exactly how you got the files from the Google Earth 3d Flyover? How were the files generated? What was the file type and then how were the used? I could see this workflow being helpful for us.
this is a project i need to get existing conditions for...so before i show up i want to have clear in my mind the sections i need to get (the old school way) so this point cloud was good enough to explain to the team what that game plan was vs trying to figure it out in the field... the blue planes are the section cuts that i want to get...
1015322532_ScreenShot2019-10-07at11_49_18AM.thumb.png.d31cfbc53d1a6f619e240fca18ca443e.png
as for how to make it...you find the 3d on google earth and then do a screen recording of you flying around with the 3d space nav then cop the video up into jpgs  (every 2 seconds?) then load to the VW cloud and select all images and choose convert to 3d model...there is a vw video on this somewhere...
860692660_ScreenShot2019-10-07at11_55_32AM.thumb.png.feb8d13a82e4324a18a821cebe9961c7.png
are you just screen capturing the 2 second images or does your screen recorder offer a frame image output of sorts? Im currently on a mac thats why I ask. I follow the process just looking for the best workflow to get there.
i cannot find an image output for Screenflow...i make a video then just move the time indicator 2 seconds and do a screen shot...its not pretty but I'm still new at this...
vw needs to take a video then have a make 3d from video and then we set up how many frame to take off video instead of us doing it
