Developer Wiki and Function Reference Links Read more... ×
GGC
WorkSheet - Call Wall Direction Function or Record
Is there any way to call the wall direction into a worksheet database setting,
so that I could set wall walls to be drawn clockwise.  During the wall layout drafting process
I would use the most efficient means to draw the walls, and eventually I would loose track
of the wall side direction.
Settings such as door and window interior/exterior trims, door and window ID tags and similar
use the wall side direction as far as I know as the left side of the direction as the exterior of the
wall and the right side of the direction as the interior of the wall.
So far I tried Pat's PIO to Worksheet PiO fields, however walls seem not to hold PIO record values.
I tried setting a wall type database worksheet, where only functions are available, however there is
no visible function to offer the wall direction option.
Over the years, I recall that there are at times functions that are not yet documented
(e.g. Pat's PIO fields to WS) , so I hope that someone in the forum may be aware of
such a function, or a similar setting to be able to set the walls direction clockwise.
I have no VS proficiency beyond simple preferences settings, as such.
I don't think so.  You can use a worksheet to ask the angle of the wall, but you can't enter a new value.  Angle is read only.
I agree with Michael. Normal straight walls don't have a clockwise or counterclockwise property. If you think about it they can't as it all depends on what you are trying to do.  If you draw a vertical wall from top to bottom and another from bottom to top, neither of them was drawn clockwise. They are just a straight line. Each has a left and right compared to how they were drawn, but that only matters because you are using components or textures that need to be on the side you want.
Round walls do have a clockwise/counterclockwise direction as that is the side the center of the curve is on.
Walls automatically generated from Spaces kind of know which way to go as they use the standard that the Left side of the wall is the outside and the right side is the inside. But as soon as it is drawn, there is still not clockwise, just left and right sids.
If you can come up with an algorithm that will reliably tell you which walls need to be reversed without your needing to look at the drawing (using the beginning and end points of the wall)to know what should be inside and what outside, I will figure out a way to script it and we will split the proceeds. 😉  And maybe we will even cut Michael in for a share.
My initial post may not have been clear.  When all the walls are joined I would like to achieve the
Start/End direction of all walls to be set in a clockwise position, so that I can easily
distinguish the interior/exterior sides that PIOs use with walls.
What I was hoping for was the value that the OIP uses for any wall to reverse sides.
For example, when all the walls are joined the start/end direction value entered
into a worksheet database would end up with two rows of summarized walls.
A set of walls with the start/end direction one way, and another set of walls
withe the start/end direction the other way.
So far it sounds like a serious VS task to analize each  wall's start/end direction
from farthest wall on the right, then each horizontal, or vertical, or angled wall with a T Join
would receive a start/end direction "clockwise", and  Corner wall join would receive
the same start/end direction "clockwise." (not to confuse withe the round wall only
clockwise option.)
I think I understand exactly what you're talking about.  I often receive drawings that have walls drawn in random directions and have to go through the all the exterior walls and check/correct them.
OK, Pat.  Here's our million dollar idea.  I haven't looked through the function reference to know if this is possible.  😜
Select a wall (W1).  Make sure it is going the correct direction.
Script:
make an array of all walls connected to W1.
maybe make an array of start points and end points?  W#.Start and W#.End.
Sort through the arrays to find the wall that shares either and start point or end point with the end point of W1.  Call it W2.
N := 1;
While N < Total Number of Connected Walls DO
BEGIN
If W(N+1).End = WN.End THEN flip W(N+1);.
END;
Maybe not worth millions, but probably worth literally tens of dollars. 🙂
