pawel@designexpress.eu Posted August 1, 2019 Share Posted August 1, 2019 how Can I joint this two elements ? I would like the notch in the roof to be done automatically Quote Link to comment
michaelk Posted August 1, 2019 Share Posted August 1, 2019 The Connect/Combine tool joins roof faces and makes cuts. It works in many circumstances. For those that don't I usually go to a Top/Plan view select the roof faces in question and then Modify > Convert… > Convert Copy to Lines. That will give you a group of lines that you can use as guides to draw the polygons to clip from the roof faces. Quote Link to comment
pawel@designexpress.eu Posted August 2, 2019 Author Share Posted August 2, 2019 ok, but I can not make a throw with a cross-section through the dormer walls and window. On plan 2d I see only roof faces. Take a look on print screens below: Do you have any tutorial how correctly create dormers and then cross section with them?? Quote Link to comment
