shorter Posted July 31, 2019 Share Posted July 31, 2019 It would be useful to have the ability to save different settings within each model for IFC export. The 'Save Settings' button chucks you out of the Export IFC dialog. It shouldn't. It should also have the same sort of dropdown menu as we have for DWG export. Current behaviour permits one setting saved per file. 1 Quote Link to comment
0 shorter Posted July 31, 2019 Author Share Posted July 31, 2019 I have also often wondered why IFC import does not have the same origin options as DWG. IFC import and spatial coordination is as important as DWG. Define your origin, save a template, import aligned to defined origin as one should in DWG world. Could not be easier. Coordination, done. Quote Link to comment
shorter
1 answer to this question
