WhoCanDo
Custom Tool point of insertion
Hi,
I'm making a custom tool that places text, with data attached, onto the drawings.
If the user picks a point on the drawing, how do I determine where that is? How do you get feedback from the tool?
The click to insert the object into the drawing will be the origin (0,0) of everything you code inside the object. Just like in a symbol.
You can get a handle to the PIO with GetCustomObjectInfo. Then you can get the coordinates of the insertion point with GetSymLoc3D.
That could help if I needed to move the text from 0, 0 at a later stage ☺️
But I would like to know where to move it. I would like to know where the user clicked to place the text.
If the tool was set up with parameters (eg. x1 - X Coordinate, y1 - Y Coordinate), would the recordHandle record them and how do I get them out?
Check out the User Interactive procedures in the Function Reference. Specifically the one you probably want is:
PROCEDURE   GetPt
(VAR pX:REAL;
 VAR pY:REAL
This returns the X and Y coordinates of the position the user clicked at. Use that as the insertion point for your object.
That's too simple, but it works ☺️
I tried MouseDown without luck to I thought it needed some Tool command.
Thanks.
