Well, I'm thrilled. THRILLED!  I can actually use Publish!
In past attempts in all these years, the published pdf sheets always produced excellent on-screen representations. But any print to paper (my former inkjets, my more current laser) created stacked up text.  All characters in a word would print on top of the first character.  Next word would be a new stack etc. At least the spacebar produced some space between the stacks.
My Vectorworks publish prefs were set to enable Subset Fonts. Disabled the Subset Fonts pref and print to paper works as expected.  So, I guess it could be my printers (but they were current tech at time of purchase). Here is a complaint list:
•  Dialog for Publish To Options (Export PDF Settings) is gray unless an item in the publish list is selected/highlighted.
•  Dialog is also unavailable is ALL items in the list are selected/highlighted (even if they are all sheet layers, or all Saved Views, etc)
• Hover the pref in the dialog produces nothing in the clue box at bottom . . . Unless the pref is toggled.
• Once toggled, hover produces a dialog clue but hover never worked.  Clue indicates printing may be more successful on PCL3 printers (whuzzat?) and also that file size might be larger if pref is disabled.
• My experience is not much change - a 30 page document is same file size either way.
OK, some complaints, but after some success.
-B
1 answer to this question
A p in the a there, but you got there and as importantly held the lamp for the rest of us.
Edited by mjm
