michaelk
Picking symbols
I'm working on a tool that uses 4 different symbols as components.
Currently I'm specifying the symbol as a text field in the OIP.  Not the most elegant solution.
I don't recall seeing another tool that lets you get to a symbol picker from the OIP.  And I haven't run across a VS way of building a Settings… dialog.
Is it possible to create a simple symbol picker in the OIP?  Or from a preference in the mode bar?
Sure: http://developer.vectorworks.net/index.php/VS:vsoButtonGetResource
The object has to be event and custom widget enabled.
kWidgetResourcePopup = 107
Mode bar options are a bit of a challenge in vs, but it is possible: http://developer.vectorworks.net/index.php/VS:vstResPDMenuInit
The OIP resource popup is somewhat limited in VS. If you want more complex behavior, use a button to launch a dialog with a resource picker.
Thanks, Joshua.  That is super helpful.
So vsoButtonGetResource creates a button in the shape pane of the OIP?  Like the Settings… button on a door or window object?   How does it know where to put the button in the OIP? (he said without reading up on it).
There goes my free time for a while.
No, vsoAddWidget or vsoInsertWidget adds the widget to the OIP. vsoButtonGetResource is what you call in the button handler to raise the resource picker. You specify the parameter that actually stores the name of the resource.
Do you need to see the graphic of the symbol? If not, why not just add the symbol name to a popup parameter.
I have not used vsoButtonGetResource because it is only available from VW 2018. I created the following dialog in 2014, Select Sign Legend, which would be similar to that. The dialog is activated by clicking on the OIP LEGEND button and the selected sign is store in the Sign Type parameter. Other parameters get their value from the record attached to the symbol.
The following is a variation of the same idea but the dialog has a tree picker control instead. I created this plugin to scale symbols before the capability was added to symbols.
  • Love 1
Miguel
That is really cool.  It makes me think about a lot of things…
In this case I need to be able to make new symbols on an ad hoc basis.
But wow.  That is cool!
