Rotating and offsetting text
I have a parametric path object.  I'm inserting symbols along the object that are tangent to the path.
I also want to insert a string value at each point also tangent to the path and offset a given distance perpendicular to the tangent.
I can insert the string at the point.  Not having any luck rotating the string or offsetting it.  Can someone point me in the right direction?
Can't figure out what function will rotate the text around its center point and what function will move it a given distance perpendicular to point along a path.
BEGIN
        BTest := PointAlongPoly(ControlGeometry,(DistanceBetweenPoints * N), PtAlongPath,TangentAtPoint);
        TangentAngle := Vec2Ang(TangentAtPoint);
        Symbol(MySymbol, PtAlongPath.x, PtAlongPath.y, TangentAngle);
        N := N+1;
    END;
Thanks!
If you already have the Tangent, then getting the perpendicular vector should be easy.  Function Perp will get you the vector perpendicular to the Tangent (You will have to decide you need the positive or negative version).
Vec2Ang will give you the angle. If you know the distance you want to offset the text, the X and Y distances should be just trigonometry.
And I thought you were a Maths Major. 😉
  • Laugh 1
Michael,
   Vectors are our friends.
Perp(V);    { is a 90° CW rotation }
Perp(-V);   { is a 90° CC rotation }
UnitVec(Perp(V)) * aDistance;    { scales the vector to exactly the distance you need }
where "aDistance" is any real number.
The position of the text is point P on your path (a Vector not a Point) + your offset vector (UnitVec(Perp(V)) * aDistance).
So:
Voffset := UnitVec(Perp(±Vtan)) * Doffset;   { the distance between the path and the text object }
Ptext := Ppath + Voffset;     { the new position of your text object }
where Ptext, Ppath, Vtan, and Voffset are Vectors and Doffset is a Real, and this assumes you already know Vtan, Doffset, and Ppath.
You can also use SetTextOrientation() to position and rotate your text object.
SetTextOrientation(H, Ptext.x, Ptext.y, Vec2Ang(Voffset), False);
You'll have to play with your angles, but I bet you're only off by a multiple of 90°.
HTH,
Raymond
PS - Embrace your Vectors, but not the pointy ends.
  • Like 3
