Markvl Posted July 23, 2019 Share Posted July 23, 2019 Wondering if there is a function or a symbol idea to making suite numbers or Suite Type letters. So for example I've got a large multi-residential building with say 40 suites on 4 floors with 4 different suite layouts. How would you go about labeling them? Not which unit is 101, not do I start to the left or to the right, but the label itself, something that acts like a symbol but is very easy to edit and populate throughout a floor/layer and something that is scalable. I've attached a pic to give everyone an idea of what I'm getting at. Right now the Unit type is a simple text object ("Type A, Type H, etc.") and the unit number is a red rectangle with rounded edges and a separate text object above it that says ("101, 201, etc.") Quote Link to comment
Markvl Posted July 23, 2019 Author Share Posted July 23, 2019 Hmmm...There is the Room Name Simple Tool in the Dims/Notes Tool Set Quote Link to comment
RussU Posted July 23, 2019 Share Posted July 23, 2019 Although I'm not an expert, I reckon what you're after would suit Marrionette perfectly. @Marissa Farrell would be able to give you much more info than I could Quote Link to comment
Wesley Burrows Posted July 23, 2019 Share Posted July 23, 2019 If I'm not mistaken this is exactly what the Data Tag is for. But it has to attach to an object, such as a "space" or whatnot to obtain the info the tag displays. 2 Quote Link to comment
Marionette Maven Marissa Farrell Posted July 23, 2019 Marionette Maven Share Posted July 23, 2019 I agree with the suggestion of Data Tag, but if you find that it's not a reasonable solution, we can absolutely tackle this with Marionette in one way or another. Quote Link to comment
