Acip79
Error on PDF Export
Hi All,
I have another issue on VWX2019. Basically my spaces area are showing finish floor level (ffl) and structure slab level (ssl) and it is controlled by using spaces. The problem is, it shown exactly like i wanted but once i export it to pdf my ffl & ssl will show the same figure. And my level indicator changed from triangle to square. Do refer the attached image.Any help on this matter? 😇😇😇
FFL - SSL exported to PDF.pdf
Hi All,
Done a study on this issue. Currently my model is referenced into my sheets file using 'layer import' option (based on suggested way to do it in Best Practice for Workgroup BIM). I tried to use 'design layer viewports' option and the issue on PDF is resolved. But I need any opinion if that is the correct way to do it or it will cause any other issue later on.
Thanks,
