Scott61 Posted July 18, 2019 Share Posted July 18, 2019 I have had this issue before, last year, and cannot remember the fix. I have a cery simple two wall floor plan, go to any 3-d view, the walls show up rendered, then disappear to what I have pictured below. Any help??? Thanks Scott Quote Link to comment
Guest Wes Gardner Posted July 22, 2019 Share Posted July 22, 2019 @Scott61, if you can post the file, I'm sure someone will get you squared away... Quote Link to comment
Scott61 Posted July 22, 2019 Author Share Posted July 22, 2019 Thanks for the response but over the weekend I started over out of frustration. I tried so many things to get the walls to stay visible that I tore apart the drawing (in the end) so what I could send would not make any sense. Thanks again. Quote Link to comment
BG Posted July 22, 2019 Share Posted July 22, 2019 Your objects aren't far away from the origin are they? I had a file that was not showing some objects and it was an origin issue. As soon as I centred the origin on the objects, it started behaving correctly. Quote Link to comment
Scott61 Posted July 30, 2019 Author Share Posted July 30, 2019 Turns out this was caused by the program and computer needing to be cycled. When my mid 2014 macbook pro, 16/1T I7 processor renders this after drawing, I must then shut down the program and restart the computer for it to render correctly. Every time.... This quirk causes any large symbol or drawing block to either not render correctly or appear in the wrong place. This has happened several times when I change the texture on a surface, it shows up briefly with the new texture, then reverts to the old one. Whether this is a program issue or my computer is unknown. Quote Link to comment
